09-27-2008, 06:31 AM
Re: cutting off (no codes)
Need a few questions answered.
Unfortunatly a vehicle that has a driveability concern like yours without setting fault codes requires diagnosing each system seperatly and eliminating that system as the cause. Do not overlook anything or assume it is correct or you may jump right past the problem. Also in order to properly help we need numbers and more detailed info so....
1) Does it backfire thru the intake or the exhaust?
Be absolutly positive that cam timing is correct, 1 tooth off will create all types of problems. I am sure you already know that the Cam is aligned 12 o'clock with the centerline of the head not 12 o'clock straight up and down.
Is belt tension correct?
2)What are the fuel pressure numbers? Connect your gauge and tape it to the windshield and drive the vehicle under the problem conditions, what is your rail pressure and what is the vacuum/boost reading, you need both to determine total pressure across the injectors. (that is how mpfi works)
Static pressure is 53-57 psi, you will lose 1psi of rail pressure for every 2"hg applied to the fpr and rail pressure should increase 1psi for each lb of boost.
Get the car hot, shut it down, watch the pressure, is it holding or did it suddenly drop?
Now crank the engine in your" hot hard to start condition" what is rail pressure reading?
3) What is engine vacuum at a manifold source at idle? Are you reading the same at the baro solenoid? Are you reading the same between the baro and map sensor?
Is map voltage reading = to vacuum/pressure?
(voltage charts can be found in the "sticky", voltage tables.)
Tee a vacuum gauge between the baro and map and drive under your problem conditions, is map vacuum/pressure correct?
4) Be sure there are no exhaust restrictions, remove the O2 sensor, leave it plugged in and secure it out of the way, drive the vehicle, is the problem gone? Removing the O2 sensor will relieve any excess backpressure.
5) If all of the above check out you need to start looking at low ignition output as being the cause such as a faulty ignition coil.
FYI, If you lose the crank signal from the HEP it will not set a fault, only if it loses the fuel sync signal.
When the car will not restart hot what do you have to do to get it started?
If it just cranks and cranks and all of the above(fuel pressure, etc) are ok check for power at the + coil while cranking, is power present? If not the problem lies in the ASD relay or HEP circuit.
You may also want to perform a "wiggle test" on all the wiring/connectors while the engine is running, pull/tug/twist on the harness's and connectors at the sensors/controller/harness connectors to isolate a faulty connection.
That should keep you busy for a while, LOL, let us know the results and we will go from there.
In my perfect world we would all have access to a dyno, oscilloscope, scan tools and gauges so we could run the car under the problem conditions and monitor all the systems at once.
