10-01-2008, 05:56 PM
3.0 lebaron not starting
My Ride: 90 lebaron coupe
Engine: v6
ported my intake  and replaced valve cover gaskets, car ran fine last night and early this morning. then when i went to go to school a couple hours later it wouldnt start.  thinking its the starter because theres just nothing when you turn the key, no clicking or anything. and the battery is fully charged so thats not it. i checked and couldn't find any loose wires.
10-01-2008, 07:33 PM
Re: 3.0 lebaron not starting
My Ride: Starion
ok so you did all this cool stuff and now your car wont start. battery is for sure good? lights good, all other electrical is ok? no start no click, wires tight for sure? power at the starter big battery wire? power at the small wire when in start mode?
could problem be a bad starter? could problem be a bad neutral switch (auto) or clutch switch (manual)? could problem be bad starter relay? could problem be bad ignition switch? maybe wiring problems..
so where should you start with proper rational and pragmatic problem solving diagnosis? starter? relay? ign switch? wiring?
10-01-2008, 11:04 PM
Engine: v6
im thinking wiring problems, checked power at little wire in start position-got nothing- then checked the big one and when i did the car started. still cant find a loose connection anywhere
10-02-2008, 06:47 AM
Power on the large wire is direct battery.
Power on the smaller wire is from the starter relay and will only be powered with the key in the start position.
The starter relay will have 2 power sources(1 constant power, 1 switched ignition from the ignition switch), a ground(thru the park/neutral switch on auto trans) and an output to the starter.
10-02-2008, 09:58 AM
Engine: v6
ok, so if i have no power to the starter relay with the ignition in start position, is it a bad ignition switch? my friends daytona just had something very similar happen and thats what it was. cost him $300 to have it fixed. im not paying that much for anything on this pile of shit.
10-02-2008, 07:09 PM
$300.00, somebody got ripped off, the circuit is not that difficult unless there was a wiring issue involving opening the harness to trace an open or shorted wire.
To check the starter relay,
12 Gauge BK wire is constant battery power(hot all the time)
14 Gauge YL wire is switched ignition(hot with key in the start position)
18 Gauge BR/LB wire is ground thru the Park/Neutral switch
14 Gauge BR wire is the output to the starter
If power is good at those 2 points of the relay and the ground circuit is good but no output to starter replace the relay. If power or ground is missing get back to me and I will tell you were to go from there.
10-02-2008, 09:32 PM
In my 1990 Chrysler wiring manual, the way Chrysler laid out the wiring they are a PITA and spread out over numerous pages so I figured it was easier for me to just list the wiring.
If you want to see the wiring I will certainly post it.
10-03-2008, 06:47 AM
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Naj is totally the man, helped me a few times with my lebaron.
-Steve Reject.
10-03-2008, 06:55 PM
Thank You!!!!
10-04-2008, 04:25 PM
#12
Engine: v6
no power at YL wire on the relay.
10-05-2008, 07:02 PM
#15
Engine: v6
got the ignition switch out and found out it was the ignition lock cylinder. thanks for all the help
