10-07-2008, 07:29 PM
HELP! Tach will not work/ no signal from wire!
My Ride: Neons + Caravan
Engine: 2.5T
OK turbo mini, Stage 5 cal... Just put on a 2.5" swing valve and the exhaust pipe is at my welder, but I had to pull my mini out of the shop for a few other cars while its getting done. As far as I can remember (because surely I would notice it didn't work then) it was working fine. A few days later, I plugged in a solar powered trickle charger (after being in my neon for a week, no problem) to help keep the battery happy. The other day, I went to start it up. After starting up, I noticed the tach wasn't moving. Reved a few times, no tach still.
To determine my tach didn't die, I hooked up my laptop to my zeitronix system (which is tapped into the wire just behind the tach) to see if it sees a signal (which it has every time with no problems)... nothing.
Anybody have an idea on why I have no signal on that wire???
