Old 10-12-2008, 04:41 PM   #1
engine rpm dont go over 3000
My Ride: OmniGLHT2 + T1beater
Engine: 2.2 T2
dont go over 3000rpm its 2.5 T1 and it backfire over like 2000 if floor it
GLHfreak is offline
Old 10-12-2008, 05:05 PM   #2
Re: engine rpm dont go over 3000
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
its gotta be your timing or a bad vacuum line going to your MAP sensor.
check your crank/cam/distributer timing, then be sure that your ignition timing is at 12* wile the coolent temp sensor is unplugged.
turbo minivan is offline
Old 10-12-2008, 05:09 PM   #3
My Ride: 86 Lazer-89T2 power
Engine: 89 2.5 T2 built
Check for a clogged ex. sys.
ButchSuppe is offline
Old 10-12-2008, 05:18 PM   #4
Engine: 2.2 T2
2.5 straight on the side
GLHfreak is offline
Old 10-12-2008, 06:39 PM   #5
My Ride: 1985 Dodge Omni GLH-
sounds like a typical tps sensor
85boostbox is offline
Old 10-12-2008, 07:40 PM   #6
Junkyard Booster
My Ride: 86 GLHT
Engine: 2.2 turbo
map sensor.
roachjuice is offline
Old 10-12-2008, 08:53 PM   #7
My Ride: 87 Shelby Z
Engine: 88 2.2 T2
Feedback: (8)
Codes? Could be any number of things
moparfreak3 is offline
Old 10-13-2008, 05:00 AM   #8
Moparmaniac
RampageTurbo's Avatar
+1 on the clogged cat. Here's a freaky one that happened to me on a Horizon. It wouldn't idle right,figured out that it had the original timing belt and had jumped time so I adjusted the distributor and got the ignition timing better. After that it wouldn't rev past about 3200. I pulled the valve cover and found that an exhaust rocker had popped its pad and was sitting sideways under the cam. The exhaust valve wasn't opening completely so it was restricting the engine speed. Probably a once-in-a-lifetime freak thing.
84 Rampage (Turbo one day)
86 GLH-T (Wrecked, will rise again)
84 600 ES Turbo Ragtop (Goldie)
Shelby Lancer #417
Shelby Lancer #13
RampageTurbo is offline
Old 10-13-2008, 08:46 AM   #9
Engine: 2.2 T2
no cat
GLHfreak is offline
Old 10-13-2008, 02:29 PM   #10
Originally Posted by GLHfreak View Post
no cat
Obviously, cause it's running like a dog.
MAP vac line leaking / baro solenoid leaking... MAP off calibration... TPS off calibration / dead spot... HEP mis-triggering / trigger plate loose in the distributor... T/Belt off a tooth... Secondary ignition issues, coil, wires, etc... fuel pressure / supply.
As was asked above, CODES? A little more info to work with here? Many of the usual suspects will set codes if a hard fault, but not necessarily on a sensor operating a little off cal.
IROCNOROLL is offline
Old 10-15-2008, 09:42 PM   #11
Engine: 2.2 T2
ouin
GLHfreak is offline
Old 10-16-2008, 12:18 AM   #12
My Ride: 85 GLHT, 87 ShelbyZ
codes will tell you everything.
GLHNSLHT2 is offline
Old 10-16-2008, 01:40 AM   #13
ouin
ouin?
Remortgages | Debt Help | Loan | Mobile Phone | Mortgage Calculator
Page generated in 0.60052 seconds with 13 queries
