10-15-2008, 01:53 AM
Re: Mystery wire???
The older 3 speed automatic has a three wire switch assy. Neutral safety / power / reverse. The older manual trans has a 2 wire for the reverse light switch only.
If you have to move the gear selector to neutral to start the engine, you probably have the shifter cable mis-adjusted, and are not fully engaging the "Park" position. The neutral safety switch uses the same wires for "park" or "neutral".
