10-14-2008, 12:45 PM
Re: blinker problems
My Ride: 91 shelby daytona
Check the connector for the switch. They seem to be sensitive to plugging and unplugging. On mine it was the pins needed to be resoldered. Everytime i pulled it apart, the back of the pins were making good contact. When i pushed it together the backs of the pins were ever so slightly disconecting themselves from the little pcb board from the backside. i way to be sure if this is the problem, when you put your dash piece back in, leave the under cover off so if you need to, you can hold the connectors tight together. If it fixes the problem well then you know the problem.
