Old 11-15-2008, 10:26 PM   #1
Exclamation Strange oil problem???
My Ride: 1991 dodge daytona
Engine: 2.5 t1
Images: 6
hEY GUYS I HAVE THE 91 DODGE DAYTONA 2.5 MITS. TURBO 1 STOCK
and well heres the story i went ahead and change the oil pump and pick up tube already but when i run the car at idle and just let it warm up to half way on the guage then i experience this problem
my oil pressure guage drops at idle and i have to rev it about 2000rpms for it to come back then if you drive it it seems to get worse where you have to rev to 2500 or 3000 rpms
and well i figure guage maybe bad so i let it idle and it started to hesitate and die ...well i check my oil on the dip stick and it shows full "BUT" heres the catch i took my valve cover cap over and on the cam shaft i saw it was dry in the center and if you kept running it it kepted getting dry from middle to outside on the loops of the camshaft?
tell me does anybody have a clue on what might this be??
turbo_daytona91 is offline
Old 11-15-2008, 10:46 PM   #2
Re: Strange oil problem???
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
Check the oil pressure with a mechanical guage. That is #!!!! The stock guage is dumb.
Sounds like insufficient oil getting to the head. That can be caused by numerous things. Why the oil pump change?
phantomrt is offline
Old 11-15-2008, 11:19 PM   #3
+1
Do not trust the gauge, connect a mechanical oil pressure gauge and check oil pressure.
Old 11-15-2008, 11:26 PM   #4
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (10)
sounds like like the problem I have been having with my car. Still can't figure it out.
Which would you rather have, go fast goodies or shiny shoes?
Your feet may look good, but if your engine blows up, you ain't going anywhere.
1989 Dodge Daytona ES - T-top - 2.5l T2 with A520
1983 Dodge Rampage - 2.2l T2 with A525 (RIP)
1984 Dodge Rampage - 2.2l Carb with A525 (RIP)
1987 Dodge Shelby Charger GLHS #782 (RIP)
1987 Dodge Lancer ES - 2.2l T1 with A413 (RIP)
1983Rampage is online now
Old 11-16-2008, 01:10 PM   #5
Engine: 2.5 t1
Images: 6
yeah ill try a mechanical gauge later today...but even if i try that why would oil not reach to the camshaft only when the car is warmed up?
Old 11-16-2008, 01:11 PM   #6
Engine: 2.5 t1
Images: 6
whats your problem on your car?
Old 11-16-2008, 01:14 PM   #7
Engine: 2.5l T2
Feedback: (10)
Same problem, here is the thread, just can not seem to figure out the problem.
Oil Pressure Issue
Old 11-16-2008, 02:03 PM   #8
Does the cam get the oil it needs when engine RPMs are increased or is this only happening at idle?
Old 11-16-2008, 08:24 PM   #9
Here is the lubricating system for a 2.2/2.5L.
Any signs of sludge buildup that may be restricting the oil flow?
Old 11-16-2008, 11:50 PM   #10
Engine: 2.5 t1
Images: 6
it gets oil when rpms are increased and idle it drops and doesnt get oil on cam
Old 11-16-2008, 11:56 PM   #11
Engine: 2.5 t1
Images: 6
if its doing that where do you think it maybe be if it doesnt want to get oil up to camshaft after its warmed up?
Old 12-04-2008, 01:17 PM   #12
My Ride: 04SRT4 & 91DaytonaT1
I had the same problem on my 91 shelby I changed the oil sender unit and that worked for me
jtcm4fam is offline
Charity Gifts | Internet Advertising | Moneygram | Credit Expert | Mortgages
Page generated in 0.41446 seconds with 13 queries
