Old 12-02-2008, 06:08 PM   #1
still having problems with turnsignals
My Ride: 1993 Dodge Daytona
Engine: 2.5 liter 4cyl
Images: 3
alright hears the situation on my 93 dodge daytona the turn signals work almost all the time but every once in a while they quit and so do the flashers I have been told that it could be everything from loose wires to a bad switch could someone help
corey simon is offline
Old 12-02-2008, 06:14 PM   #2
Re: still having problems with turnsignals
Switch's are a common problem with intermittants but the flashers will not be affected since the 4 way flasher switch is on the column.
I just replaced my switch due to an intermittant condition and when it acted up I would just keep turning the switch on/off and they would start working again.
90-93 Daytona and 90-95 Lebaron use the same system.
The only thing the turn signals and flashers have in common is the combo-flasher.
When they stop working do the indicators still illuminate and just not flash, if so do both sides illuminate?
Old 12-02-2008, 06:28 PM   #3
Images: 3
when then turn signals don't work the indicators don't work either, yeah I flick either side on nothing works indicators or signals
Old 12-02-2008, 08:35 PM   #4
If time permits tomorrow I will see if I am able to get the wiring for a 93.
Old 12-02-2008, 08:38 PM   #5
Images: 3
thanks
Old 12-03-2008, 06:58 PM   #6
All I was able to get was a wiring diagram, was not in work long due to a doctors appt and will not be back till Monday, Bronchitus.
Here is the info available from my 1990 FSM which should be the same, 90-93 Daytona used the same switch's.
Mbna | Personal Finance | Loans | Loans | Personal Finance
Page generated in 0.32416 seconds with 13 queries
