12-04-2008, 04:31 PM
Re: Thermostat sealing
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
it's a VERY common gasket ; should be no problem finding one
I prefer to use the gasket with a thin layer of 'silicone blue' or permatex on each side, but its also possible to run with no gasket...
if U want to do that, I would make sure both surfaces are VERY clean, and flat; then put a medium thick layer of permatex on each surface ; let it "skin" for 10 minutes before assembling
RESIST the urge to overtighten the bolts or you will squeeze all the sealant out
