07-22-2003, 06:15 PM
My Ride: 1988 Daytona C/S
Engine: 2.2 Turbo II
Air in coolant? Try removing the plug on top of the thermostat housing on the head. Then fill the radiator with the plug off the head. Fill it until coolant comes out the hole then put the plug back in. Then just fill radiator/overflow can.
Did you drill a 1/16 hole in the thermostat? By the way, which thermostat do you have in there?
Do you have an aftermarket temp gauge? If not, I'd say get one (I got a cheap one for 15$CDN at Crappy tire) If you already have one, how many degrees does it get to?
07-22-2003, 07:20 PM
My Ride: turbochrysler.com
Still might be an air bubble, I've had some cars that took a lot of time to get bled out, even with a hole drilled in the t-stat.
My GLHS was dumping antifreeze out the overflow every time I turned it off, was fine when running. Ended up being a leak where the hose from the overflow connects to the radiator, it was sucking in air instead of coolant.
07-22-2003, 09:17 PM
My Ride: 88 CSX-T
Engine: 2.2 T1
I have never had too (or was able to for that matter) remove the bleeder plug on the cylinder head for bleeding the cooling system. I just start the car with radiator cap off, and let it idle until the thermostat opens - and then let it idle until the fan comes on (if you haven't bypassed it). I've always bled cooling systems that way and it has worked every time. Run with heat on some sort of setting to make sure coolant is getting to heater core. If there's air in the system, there will be no/little heat. I replace cap just before the fan turns off, then all is set.
This is all from personal experience on my cars.
07-22-2003, 09:51 PM
My Ride: mostly mopar
since your bleeder is stripped,you can loosen the top therm housing bolt to burp out the air. works everytime. hopefully that is your overheating prob. water pump impellars have been known to rust or rot away the fins and slow down the coolant flow. also might want to have rad flow checked or pressurize the cooling system.
07-22-2003, 10:38 PM
Okay guys I think it may have something to do with a blockage in th esystem somewhere or ..... a p0inner hole in the heater core. I have seen some blue haze on the inside of the windshield lately, that I can easily wipe off. I still dont smel;l the antifreeze in th ecar yet so its not that bad.
What lead me to this assumption, I was driving around with the heater on , in this 33 ^ weather, and the air coming from the blower was erratic, it woiuld be warm , tthen HOT, then warm and then HOT, then warm then almost tepid, then hot again.
07-22-2003, 10:43 PM
My Ride: '85 GLH
Trev,
Sounds definitely like a air-pocket in the system then ...
Get that plug the heck out of there at all costs!
Later,
Craig
07-23-2003, 12:32 AM
#12
My Ride: Caravan
Engine: 2.5T
1/4: 16.800
check your water pump and if you changed it it might be the wrong one. It might try to pump it backwards
07-23-2003, 12:40 AM
#13
Speaking of pumping backwards make sure the belt is on right also. Smooth side of the belt should be on the smooth pulley for the pater pump.
I just pulled the engine out of a parts car and they actually had it on with the belt under the pulley and the ribbed part riding on the smooth pulley turning the water pump backwards.
07-23-2003, 04:53 PM
#15
Sounds like you got it!
gotta watch out for those Ninja Underpants Gnomes, they'll get you every time...
