08-24-2003, 09:33 AM
My Ride: 1987 Shelby GLHS 189
Salt and pepper specks indicate to much ADVANCE... re-check your base. Are you using a zener??? What one 4.3 or 4.7?? Stage II s/b 4.7. This would cause it.
08-26-2003, 07:10 AM
Swap back to the stock box and see if the idle issue goes away. You have to fix the BASE problem before tackling others.
Adjusting the idle screw should NEVER be needed...
Sounds like a vac hose of, any codes??
08-26-2003, 11:57 AM
You DID run the extra 2 wires for the AIS correct??? SC ais does not require them... The GLHS boxes do.
08-26-2003, 01:01 PM
You shouldn't, what year MP TI module is it?? Is it the 85 or 86, they are different. To run an 86, you need the 86 and up distributer and HEP. The 85 Distr/hep are NOT compatible with 85 boxes.
08-26-2003, 02:15 PM
#12
My Ride: '89 CSX T3/T4
Engine: 153ci
P4532327 is for an 86
P4532325 is for an 85
so go make sure which one you have...
08-27-2003, 07:24 AM
#15
Originally posted by Shelby85Charger
Yes, it is P4532325. Now what?
You never got back on what the base timng was..
Take care of the basics
