Old 08-24-2003, 05:53 PM   #1
Got fuel, spark, compression, and timing is perfect
I have fuel, spark, compression, and timing is perfect why wont my van start. The injectors pulse and the spark pulgs fire. i have no clue what to do???
89turbomini is offline
Old 08-24-2003, 06:28 PM   #2
My Ride: 99 Cummins
Engine: 5.9
Images: 6
You are turning the key, correct? just teasing ya..
First thing that comes to mind is the distributor is 180 degrees off. pull it up, turn the gear thing on the bottom 180 degrees around then drop it back in and try that..
Whats it doing when you try starting it?? Hints can help.. such as sputtering, smoking, sounds? hesitation?
Timmay2 is offline
Old 08-26-2003, 01:09 PM   #3
It ran before all this happened i put it away for the night then the nexted morning came out and it wont start.
Old 08-26-2003, 01:43 PM   #4
Computer???
Did my computer take a Sh*t if so then y do i still have spark and fuel. how can i test it
Mortgage Calculator | Debt Consolidation | Debt Consolidation | Credit Cards | Mortgage Loans
Page generated in 0.53574 seconds with 13 queries
