Old 08-25-2003, 07:07 PM   #1
What else sounds like rod knock?
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
Exactly what the subject says it's in an 85 Turbo Z with a 520... any ideas what the noise could be other than rod knock? it sounds like it, but it wasn't making it before the flywheel bolts sheared off so I'm at a loss
Garret is offline
Old 08-25-2003, 08:40 PM   #2
I had that type of noise at one point that I almost pulled the motor out. I endeup changing out just the Cam and DONE. No more noise. I have a 'Slider' Cam in the car and it was so badly worn out, I replaced it with an '88 TBI roller cam and the car is running GREAT!!
Shelby85Charger is offline
Old 08-25-2003, 08:50 PM   #3
Engine: 2.5 16v
so if I pop off the V/C that should tell me if the cam is worn?
Garret is offline
Old 08-25-2003, 08:52 PM   #4
probably. could be a bad spring too. the cam is probably worn. it's just........how much?"thumbs up pop in a roller. much quieter!
15w/ashelby is offline
Old 08-25-2003, 08:54 PM   #5
Engine: 2.5 16v
won't the timing be fuggered with the roller?
Garret is offline
Old 08-26-2003, 09:49 AM   #6
Lucas
A loose spark plug can sound like rod knock, if it's loose enough it'll miss too.
Old 08-26-2003, 11:51 AM   #7
My list of odd TD noises:
Loose alternator bracket can cause intermittant knocking.
Loose flywheel/clutch (usually from forgetting loctite)
Bolts holding tranny to block backing out
The above mentioned slider cam of death
Broken piston skirt
Bad lash adjusters (more of a loud tick than a knock) - also too thin of oil can make good ones do this as well.
Toasted rod bearring
Lastly (and my favorite) someone forgetting to torque down both rod bolts so that one nut falls off and the other does its best to keep things held togeter......
The Hog is offline
Old 08-26-2003, 02:01 PM   #8
Engine: 2.5 16v
Broken piston skirt
....Loose flywheel/clutch (usually from forgetting loctite)....
Funny guy
but thanks I'll check most of those out
Garret is offline
Old 08-26-2003, 02:39 PM   #9
My Ride: Dodge Omni GLH clone
Engine: 2.2 inline 4
Pwr steering pump bracket coming loose
Piston slap
Teeth broken off of distributor/oil pump intermediate shaft can knock as well.
omnivore is offline
Secured Loans | Adverse Credit Remortgage | Mortgage insurance | Mobile Phones | MPAA
Page generated in 0.40613 seconds with 13 queries
