08-29-2003, 05:58 PM
I Hate Cars!!!!!
heres the story, i have an 86 glhs omni, 2 weeks ago i went to swap intake and exhaust manifolds for ported ones....NIGHTMARE!!!.....after 2 days of trying to get the manifolds off, i decided to take the head off (15 mins of work). so i ported the head and got the valves done while it was off, got a set of +20's, AFPR, relocated batt. in trunk, 52mm t-body, replaced all plastic vac. lines, removed the EGR valve and cleaned all sensors: IAC, IAT.......
problem number one- as soon as the key is turned forward the fan comes on.....possibly fan switch, however it's only like 3 weeks old.
problem number two- when you give it gas, it revs up and kinda stays there at that rpm for a minute and then comes down to idle.... idont remember it being so slow to recover before?
one thing i havent done yet is set the fuel press., since the regulator is used , i would ass-u-me its somewhat right. tommorrow i'm gonna borrow a fuel press guage and set that. i hope one of these problems are from removing the EGR, and yes i did plug the hole.
thanks, matt
08-30-2003, 08:26 PM
yea, its back on the ground w/ the wheels on, i swapped the coolant temp sensor for the old one i had and the fan didnt come on when turned the key forward, but it also didnt come on when i unplugged the sensor, like its supposed to do. i also noticed, after i redid the timing belt, i was setting the timing (CTS disconnected) i set the dist timing at stock 12 deg. and when i plug the CTS back in , instead of advancing a couple degrees at idle, like it should.......it retards the timing to around 0 deg.??????
WTF is goin on here???? any suggestions?
thanks, matt
09-01-2003, 12:23 AM
well, i spent all day messin with the car today, i got the timing as close as i can get it without an adjustable cam gear. no matter what i did it was a half a tooth off from the haed being machined 2 times and the block was decked before. i already cleaned the IAC motor, i have a brand new one i put in and when i started the car, it wouldnt come down past 4k rpm's. so i took it out and left the plug in, and turned the key forward a few times.....it did nothing, it should move out as far as it goes.
then i got the codes from the comp. theres one for speed sensor (newer sensor) because it takes soo long to come down from an idle. the next code was the coolant sensor....incorect voltage, this is the old sensor i swapped out. the last code was throttle position sensor....incorrect voltage. and the first time i pulled the codes, there was one for the IAC. i'm thinkin the IAC isn't gettin power. but i think the IAC gets signal from the speed sensor and the TPS, maybe they all share a ground or somethin?
09-01-2003, 08:12 AM
My Ride: 1987 Shelby GLHS 189
My block was decked .028, head .007. That's .035" and pretty severe. Never had the cam a "Half" tooth off.
The SDS and tps provide inputs to the computer used by the AIS.
09-01-2003, 06:15 PM
today, i checked thee plug for the IAC with a test light, it has power on two of the four wires. i also checked the TPS for power, but it wasn't enough for the test ight, so i used a multimeter, i dont really know how to work that thing, but it was gettin power. i redid some grounds also. it still doesnt settle to an idle like it should. then i started it with an intake vac. line disconnected and it felt like it was somewhat misfiring, but it cam right back to idle ?????
oh, i'm also burning oil now, since i put the head back on. and last night it was doin it real bad when i first started it, it was also running pretty rich....some of the smoke was fuel??? i set the AFPR at 47lbs at idle, injectors are +20's could it be too much fuel? maybe thats why it ran better when the vac. line was off?
