09-06-2003, 02:31 PM
please help, i am at ready to quit- code 44
My Ride: 1994 Dakota 4x4
Engine: 318 V8
hello,
i posted previously about a code 44 that i am getting. Has anyone else ever gotten a coder 44? I know it is the FJ2 wire, and have already been to MiniMopar, but i dont know which wire it is and i have to clue whatsoever how to find it. I bought a little cucuit tester and the light woudl come on for some wires, but not for others. Does ANYONE at all have any clue how to help me. It wont idle and therfor you have to hit the gas to get it to start and it runs rpetty bad. I also changed the SMEC jsut to see if that would fix it, but it didnt. Same thing. Does anyone have a wiring Diagram? I think i should jsut buy a new SRT....i loved working on cars, but after the 4 years of trouble this thing has given me i am ready to shoot myself (not really, but close enbough)
thanks alot
09-06-2003, 06:09 PM
Engine: 318 V8
THANK YOU for replying....i was gettin pretty curious as to why the resource himself hadnt helped yet..hahah by the way, it is much appreciateed. I went to the dodge dealership here adn the guys in the shop let me look at a shop manual, electircal wiring diagrams, but it took me probably like..2 hours to find what i was looking for. Once i found that, i got it photocopied and it has a list of all the connectors and where they go. I checked #4, as it is the J2, and it had 12V or so with the ignition on, and none with the ignition off, which is right. This was all i knew what to check for, so i checked just to make sure that there was current from the 17-20 pin connectors (AIS WIRES) to the AIS, and there was...so i was stumped. I tried using booster cables to make more grounds, but it didnt help. Also, when the car is runnning ( i havent driven it, jsut tried to start it, and had to use the gas a bit) the fan comes on right away. It NEVER did that before, only came on when the temp got up to a certian point. I have no clue why it is doing that. **** car. I will go check the other pins in which you told me to, and let you know. thanks alot again...
09-06-2003, 07:32 PM
Engine: 318 V8
okay mr. overland, and all others reading, i tested #4, the J2 wire. It was good, at 12+ V. I tested #3 (both of these on the 14 pin connector) and there was nothing. I tested # 12 on the 60 pin. Nothing. I found the splice, with the wire from the 60 pin connector not connected. it was all green adn corroded. I took the splice apart, and there was one wire that goes to the 14 pin connector, and the other which went to the little box on the finder (not the fan relay or the starter relay, but the other relay box on the actual fender). Into it goes one blue/whie wire (the one that goes to the splice), a larger RED wire, which always has power, a large Green adn black wire, and a smaller blue and yellow wire. I reconnected the splice up, cleaned the wires off good, made a good connection, so one blue and white wire comes out of the relay, and then splits up and one goes to the 14 pin connector one goes to the 60 pin connector. All seems well. Still NO voltage at the #3 or #12. ????? Ignition was on, but still nothing. what else coudl it be? i fixed the broken wire.....i am lost again. Could it be that relay or something?
09-06-2003, 09:05 PM
Engine: 318 V8
hey there,
sorry to put you through all of the extra trouble, i jsut disconnected the battery again, plugged everything in (14 and 60 pin connectors) to the SMEC and put the battery back on , and it fired right up fine. Thanks sooo much....you have no idea how much i appreciate it. If you ever need anything i can help you with, let me know. I put the stock SMEC in jsut to see what the difference would be, as when i turned 16, i got the MP SMEC, and my license, and never drove it with the stocker. What a difference i tihnk. That extra 2 psi makes a difference. You also saved my ass from missing the street legal drags tomorrow. thanks soo much again. 3 cheers to PER OVERLAND..haha
