Old 09-17-2003, 04:19 PM   #1
Stutters under acceleration...tried everything
'87 Shadow ES turbo I...new cap, plugs, wires, coil, pick up, etc. Timing is dead on. Fuel pressure is 51# at idle. When you accelerate hard in the gears it wants to stutter very bad. Mechanic has hooked it up to the osciliscope and gets eratic wave patterns. Everyone is stumped! Please help. Thanks in advance.
ohioglhs is offline
Old 09-17-2003, 09:40 PM   #2
My Ride: '89 CSX T3/T4
Engine: 153ci
what do the spark plugs looks like?
TurboXT is offline
Old 09-17-2003, 10:43 PM   #3
if any are really wet do a compression test
csxt#10 is offline
Old 09-18-2003, 06:15 AM   #4
**** thing
The spark plugs are brand new. The compression is from 85-92 and should only be 100. What particular am I looking for on the spark plugs (wet, burnt, etc?). Thanks guys for your help. My mechanic is also calling a "tech line" today.
CSX#10...maybe I should have bought your CSX!
ohioglhs is offline
Old 09-18-2003, 07:23 AM   #5
maaybi if i just didnt replace a cracked piston it had
csxt#10 is offline
Old 09-19-2003, 12:04 AM   #6
My Ride: GLHS Charger
Your compression should be closer to 125-140 psi. Check for loose grounds. When did it start happening. Need more details.
MVaughn is offline
Old 09-19-2003, 12:11 AM   #7
Engine: 153ci
the reason i ask is because when my car did that not too long ago i remembered that i have TII injectors in there. so i checked the plugs and they were BLACK! so i put some stockers back in and it went away "thumbs up
that might not be your problem but i thought i'de add my 2 cents. you also might wanna check the FP while your driving too
TurboXT is offline
Old 09-19-2003, 06:41 AM   #8
Still Doing It!!!
I just bought the car as a beater...so it has done it since I purchased it. My mechanic said that the spark plugs are dry. I thought he looked up the compression and he said that it should be 100...is 125 correct? I do know that the cam is making some noise...they took the valve cover off and there are some scratches on the lobes. If compression is supposed to be 125 would a head gasket cause this? Thanks again.
Mike
ohioglhs is offline
Old 09-19-2003, 02:57 PM   #9
Ive been having the same problems.
Air/Fuel reading pig rich at WOT.
I still have solved this problem.
-toddi
toddipoo is offline
Credit Counseling | Internet Advertising | Mortgages | Loans | Loans
Page generated in 0.36406 seconds with 13 queries
