09-24-2003, 01:04 PM
#26
Originally posted by cpages2
Do you guys know where I can get Intercoller hosing? My IC is mounted behind my radiator and it is using Radiator hosing for tubing.
I want to re mount my IC to the front of my car and run silicon hosing but im not sure where I can go to get it..
what do you mean "behind" your rad. I thought it was a T1. did someone install a rad/Ic combo out of a T2/T4 car?? if so then the IC would be beside the rad.
as for IC piping when using a front mount. the cheap way to do it is to buy aluminized exhaust piping, size of your choice, and cut it up and use it for the straight sections, and buy assorted reinforced rad hoses that the exhaust piping will slide into and use the rad hoses for the bends that you need. If you got money, you can buy mandrel bend piping from places and make the entire system metal with your choise of rubber(cheap) or silicone(expensive/unnecessary) connectors
