Old 09-23-2003, 08:20 PM   #1
boost gauge help
_9_
I just picked up a boost gauge from a turbo pacifica at my junk yard today. I wanted to know if there was anyway to test it to make sure it was working good. I also think I kinda messed it up (I always have to take things apart..), the needle was off so I wanted to make sure it wasnt stuck or anything, took the cover off and moved the needle with my finger and heard like a click and then it wasn't springy any more, so I took it apart and see the gear inside, and that it was just off so I got it back on the gear but am not sure it would work correctly or not. Thanks in advance.
Courtney
_9_ is offline
Old 09-23-2003, 08:38 PM   #2
hook a hose up to it, and blow...lol, if it reads more that 5psi, then its off, because you would have to be realy realy kick ass to produce well over 5lbs with your mouth.
Chris
mastwolf is offline
Old 09-23-2003, 09:17 PM   #3
_9_
hmmm... interesting, maybe I'll try that tomorow. I need to find some sort of regulator to hook up to a pump maybe so I can find out exactly how much it should read. Thanks though. It's the thought that counts .
Courtney
_9_ is offline
Old 09-24-2003, 09:39 AM   #4
_9_
so I hooked up a basketball/football hand pump to it and can get between 6 and 10 psi according to how forcefull I am. Does that sound right to anybody?
Courtney
(waiting to fix his omni to see if his boost gauge works)
-Oh yeah how do I hook this up? form the vacuum line coming off the turbo to the wastegate maybe?
_9_ is offline
Old 09-24-2003, 02:48 PM   #5
My Ride: 99 Cummins
Engine: 5.9
Images: 6
Go off a nipple off the intake or throttle body... a sorta easy way to tell if its accurate or not is to hook it up and drive a short distance with a turbo outlet hose disconnected (any intercooler hose popped off).. when you floor it the boost gauge should read 0 dead on if its still decently accurate.
dfasdaljdfjkasdfgaqyh
Timmay2 is offline
Movies download | Debt Consolidation | Overstock.com | Car salvage | Dirty Dozen Brass Band
Page generated in 0.32613 seconds with 13 queries
