09-26-2003, 10:23 PM
#23
My Ride: 88 Turbo Lebaron
well, cam timing was DEAD ON! but now that i have the ignition timing set right it still seems to still lack power. take off is where it shines... but then its like nothin after take off.... im lost now. any ideas? its timed at 13degrees, new plugs, new cap and rotor, cleaned tb, ran some fuel injector cleaner not too long ago, 93 octane gas. however it does run a little lean, and the a/f gauge doesnt seem to read right, maybe the o2 sensor? i used copper wires bad idea? its not the ground... its grounded right to the battery and the sensor wire is hooked up right. while idling or letting off the gas it will drop down and no bars will light for a few seconds, they dont come back up as fast as it use too. the plugs do indicate that it may be running a little lean. no fault codes showing up. only thing that i can think of that hasnt been replaced recently is the plug wires. i guess i can go get a set tommorow. any ideas? thanks guys
