Old 10-05-2003, 08:33 PM   #1
No Boost! Help Please. Im Clueless
boomans shelby
I have a 1988 shelbyz t2. I was told by a small time shop that my wastegate diaphram is bad. What are the symptoms of a bad diaphram. MY car will only boost about 2-3 pds. I spent at least $1500 trying to get this thing together. I was also thinking could it be a vacuum leak, and if so do you have any diagrams on how the vacuum lines should run? Please help me.
Old 10-05-2003, 08:40 PM   #2
mitsudodge
Although the vac diagram under the hood is the best guide, Gary Donovan has them at his site "thedodge garage.com". I think that when your wastegate diaphragm is shot you get overboost not underboost. You'll find the advice "check your wastegate arm" all over these forums---good idea.
Old 10-06-2003, 09:48 PM   #3
I'd check the wastegate arm first. it wouldn't be a vac leak, that would cause overboost.
shlbyturbo is offline
0% credit cards | Debt Consolidation | Credit Cards | Share Prices | Property for sale in Spain
Page generated in 0.39935 seconds with 13 queries
