Old 10-06-2003, 05:46 PM   #1
HEP Troubles
I am curiouse about the trouble that "silverblue85" had with his HEP in the distributor. Since the 87's have the larger distributor, did they also have this same problem? or was it only in the smaller distributor HEP's ?
thanks
2GLHSs is offline
Old 10-06-2003, 07:24 PM   #2
HP=(mph/234)^3*weight
all of them.
If you replace the HEP, MAKE SURE there is no contact between the HEP and the shutter. I destroyed a brand new HEP this way. Had to shim the HEP up a bit 'cause something wasn't right in the distributer. Should have replaced the dizzy, but sometimes ya just can't afford to do it right!!
Old 10-06-2003, 08:01 PM   #3
thanks. just swapped HEP's from 609 to 615 "GLHS #'s that is"
car still wont start....just puts out a small back fire now and then.
probably somthing else...perhaps it jumped time.
2GLHSs is offline
Loans | Loans | Auto Loans | Ringtones | Credit Card Consolidation
Page generated in 0.39171 seconds with 13 queries
