10-21-2003, 02:33 PM
My Ride: 1988 Shelby Z
Engine: 4Banger Turbo 2.2L
1/4: 15.500
id do a complete tune up.
cap/rotor/wires
set base timing. Check fuel pressure, make sure everythings good.
Compression check.
Get 2 guages, Boost and EGT.
Dont bother wiht an AF unless its a cyberdyne or similar type. Autometers are too difficult to read on the fly. EGT will be much more usefull. (tuning, and for every day use, you can look at it and youll know if your engine is leaning out or is running to rich)
If all is good a nice intercooler will be a must down the road.
Also get a Walbro 255 and change out the fuel filter. If you dont your fuel system will run out of breath down the road, and you WILL melt pistons.
Graingers are awesome for starters, later on you can get a cal. I dont know much about the electronics in an 86 tho sorry.
