11-05-2003, 06:36 PM
You'll need to adjust it back down to a proper level again, but you already got that down.
Unplug the AIS/TPS connector - inside there are two wires going to the AIS, and three to the TPS I believe. These tabs are held into the connector by plastic clips... on one of the two AIS wires (or both, does not matter) push the plastic clip away and pull the wire out, tape it up with electrical tape and the computer can no longer control it. So when you adjust your idle by turning the motor, the computer can't screw with it - so your in buisness.
