Old 11-07-2003, 03:15 AM   #1
need help with spedometer 91 spirit r/t
I am having a problem with my 91-spirit r/t speedometer. It intermittently works and then does not work. Specifically, it will only turn on after it is completely warmed up and I run the car hard a few times. Then there are the rare occasions when it will work right from a cold start. Does anyone know a possible cause? Does anyone know if they are electronically controlled or cable controlled? Which tire does the cable or sensor run off of? This is a real pain in the rear and I really need help!
spiritmadness is offline
Old 11-07-2003, 02:17 PM   #2
My Ride: turbochrysler.com
Your speedometer is electronic and get it's signal from the vehicle speed sensor located on the passenger side axle housing of the transaxle. These sensors are known to fail so I would start there, but there is a chance it might be a bad gauge too.
Turbodave is offline
Credit Counseling | S65 AMG | Debt Consolidation | Bankruptcy | Refinance
Page generated in 0.31986 seconds with 13 queries
