intercooler hose help. - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 8 Old 09-02-2012, 05:00 PM Thread Starter
My Ride: 1986 Dodge Daytona
Engine: 2.2 turbo
I converted my 86 Daytona to T2 specs. I had the car running and noticed my lower intercooler hose was collapsed. I was thinking of getting another used one but would it do the same thing? Can I put a spring from a radiator hose in the IC hose? The hose is kind of worn and soft. I dont want to buy an ebay kit. Has this ever happened to anyone else? I have searched on here but nothing promising.
dj'sr/t is offline
post #2 of 8 Old 09-02-2012, 08:21 PM
My Ride: 1987 Daytona Shelbyz
Re: intercooler hose help.
Sure, a spring from a radiator hose would solve the problem.
87blueshelbyz is offline
post #3 of 8 Old 09-03-2012, 12:03 AM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
No hoses should be collapsed on a T2 setup since no hoses would be under vacuum.
GLHNSLHT2 is offline
post #4 of 8 Old 09-03-2012, 12:32 AM
Das Beste Oder Nichts
92TurboTona's Avatar
My Ride: 92 Daytona
Engine: 2.5L T1
would be under pressure and if it collapsed then something is def not right, either its just that weak or its the incorrect hose
but your best bet would be to see if a muffler shop can mandrel bend you a small section for replacement
92TurboTona is offline
post #5 of 8 Old 09-03-2012, 12:35 AM
My Ride: Tona VNT, Shadow ES
Engine: 2.2, 2.5
I was going to say the same thing as goes like hell and stops like hell. You shouldn't be seeing a lower intercooler hose on a TII car collapse. Definitely strange. I have seen the blow-through T1 charge hoses collapse momentarily when snapping the throttle open quickly. But never under any circumstance on a blow-through intercooled engine seen a hose collapse. And I am unfortunately unable to come up with a reason why this would be happening on your car. Though it is in fact possible as you say it is happening. Maybe someone can chime in and come up with a scenario that would cause it.
[SIGPIC][/SIGPIC]
90 Shadow ES - Intercooled 2.5L - Repainted, ES body kit removed, CSX-VNT rear wing added, 16" pumpers
TurboDodge is offline
post #6 of 8 Old 09-03-2012, 01:39 AM
Only way that it would collapse is if you had a significant restriction in the air box.
TBird232ci is offline
post #7 of 8 Old 09-03-2012, 10:38 AM Thread Starter
Engine: 2.2 turbo
What about too much air? I have a free flowing K&N filter hooked up.
dj'sr/t is offline
post #8 of 8 Old 09-03-2012, 01:35 PM
TD Extreme User!
My Ride: 90 Daytona Shelby
Images: 12
Garage
Is it just collapsing for an instant right as you open the throttle? There's absolutely 0 reason it should be collapsed once the turbo spools, but in the lag moment from open throttle to spooling it could collapse for a very quick instant.
The problem is that with years and miles the heat cycles weaken the rubber. Then you get oil leaks which eat into it and you end up with a soft rubbery mess. Honestly, it's not so common as to be something to worry about. Just find another one from someone on here or make your own with some rubber couplers and a metal tube. There's nothing magical about the stock hose other than it's molded to fit the space easily.
-Brian
90 Daytona Shelby
96 Jeep XJ
EvilcowRoland is offline
Human Verification
