09-06-2012, 10:33 PM
#14
Re: Injector problems after sitting 10 years
Level 1 Supporter
My Ride: SC/GLHS(2)/CSX
"That's the first time I heard of it and I would not recommand it at all. For easier to take off the fuel pressor regulator and/or remove the valve cover to give you the extra room than take apart the 2 piece intake manifold."
Yeah....I totally forgot to mention that you do HAVE to take the FPR off and removing the VC also gives you a little more room to work. I leave the VC on now, I've done it more than a few times. There is always some concern about dragging the tips of the injectors over the hole edge of the intake where the injector tip goes in. I've not had this problem since I discovered that if you push the harness and the injector connector behind the fuel rail before trying to remove it. I find this to be waaaaay more easier than removing the clips and wiggling it apart then reversing the order on reassembly. Its not so easy to not drop or sail one of the clips right into the great beyond or another parallel universe where it can't easily be found.
It's really a matter of personal preference though all these suggestions are tried and true for the most part we have all tried it a number of ways. Point that is important here is that you're careful to not bang the injector tips, and new rubber seals are SUGGESTED when you take the injector out of the fuel rail. If the seals are older, when you reinstall them, they are probably rather hard and/or brittle and MAY leak under pressure...a little or quite a bit. So put in new seals just to be safe..and Oh! BTW, when you put in new seals it is very difficult most the time to get the injector back into the rail unless you've got a good working angle where you can apply an appropriate force to get it in place.
