brake boost vac check valve - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 11-11-2012, 08:54 PM   #1
My Ride: '88 Turbo New Yorker
MrsArcade is keeping the peace
It appears the check valve is bad on the brake booster. I removed the check valve, started the car while plugging the check valve. When the car was turned off the vacuum did not stay. If I replace the check valve and cannot get one with multiple vacuum ports, I assume I can jut t in so everything is hooked to vacuum?
MrsArcade is offline
Old 11-11-2012, 10:19 PM   #2
Re: brake boost vac check valve
CHAMPION OF THE LOG
onerippinturbo2's Avatar
My Ride: 85 shelby charger
Engine: 2.2l sohc bored.20
1/4: 12.550
Feedback: (41)
onerippinturbo2 is keeping the peace
sure, but you may wanna ask at the parts store the "help" rack usually has booster check valves on it. or hit your local pick n pull and grab a few.
onerippinturbo2 is offline
Old 11-12-2012, 05:30 AM   #3
NAJ's Avatar
Feedback: (21)
To verify brake booster/check valve operation...
1)With engine off pump brake pedal until it is hard.
2)While holding foot on brake pedal start the car, the pedal should drop.
3)Shut the car off and pump pedal, you should get 2-3 pumps of assisted braking before pedal gets hard.
