1987 csx starting schematic needed - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 11-12-2012, 02:20 PM   #1
My Ride: 86 Shelby Charger
Engine: 2.2 8V
turbo-charger is keeping the peace
I bought my 1987 csx as a roller so now that I'm trying to get it started I'm not sure everything is right. It won't crank when the key is turned. Anyone have a schematic for the starter system?
turbo-charger is offline
Old 11-12-2012, 07:52 PM   #2
Re: 1987 csx starting schematic needed
Cloud car owner.
GhostDaytona's Avatar
My Ride: 96 Dodge Stratus
Engine: 2.4L DOHC
GhostDaytona is traveling down a dark road
Hey did u buy tht car from the guy in burleson who
Has all them turbo mopars on craigslist???
If do, did u see any 86 turbo z's out there???
Any digital dashes??? 87-89 cars??
GhostDaytona is offline
Old 11-12-2012, 08:07 PM   #3
Engine: 2.2 8V
No I bought it from a friend who's getting out of turbododges. That guy in Burleson does have some 87-89's but I've never been able to deal with him. He's about as flaky as they come. If you agree to a price with him you better pay him right then and get the car then or the deal can change.
Old 11-12-2012, 10:53 PM   #4
My Ride: 83 Dodge Rampage
Engine: 2.2L Non Turbo
wpgrango is keeping the peace
what exaactly does your car do when you turn the key.... does it click, do lights come on etc....
More info is needed..
Your schematic is fairly simple.... positive from battery to stater, Negative to block.... ignition to solinoid etc....
wpgrango is offline
Old 11-13-2012, 07:11 AM   #5
NAJ's Avatar
Feedback: (21)
PM sent with the starter system schematics.
All models are the same 85-89 except 87 SC.
2 power sources to the starter relay...
1)Constant Battery
2)Switched Ignition from the Ignition Switch only in the Start Position
Ground is a ground wire on the transaxle on manual trans or thru the neutral safety switch on auto trans.
At the starter the + battery cable should be a constant 12 volts.
The solenoid wire should have 12 volts from the relay only in the Start position.
Old 11-13-2012, 10:51 AM   #6
Engine: 2.2 8V
Thanks NAJ! Turns out the Neutral safety switch was bad. It's tough troubleshooting a car that's been modified without schematic.
