87 shelby lancer bucks surges under boost - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 11-16-2012, 08:18 PM   #1
My Ride: 87 shelby lancer
Engine: 2.2 t2
moparman7 is keeping the peace
My 87 shelby lancer 5 speed has 93000 on the clock and started surging and bucking once it goes to boost over 6psi , I replaced plug wires pick up plate in distributor
Didn't help , it runs really good if u drive it normal , only does it when you put your foot in it...
moparman7 is offline
Old 11-17-2012, 06:38 AM   #2
Re: 87 shelby lancer bucks surges under boost
NAJ's Avatar
Feedback: (21)
You have to determine if this is a mechanical, ignition or fuel issue.
1)Are any fault codes set?
2)What is actual pressure (boost) reading at the manifold, verify you are not actually hitting overboost shutdown.
3)Connect a fuel pressure gauge and vacuum/pressure gauge and go for a ride, is fuel pressure in specs for boost?
4)What is Map output voltage reading under the problem condition?
5)Verify cam timing and ignition timing are correct.
