12-18-2012, 03:54 PM
#12
Re: Help! Coolant and oil leak!
My Ride: 1990 Daytona ES
Engine: 2.5l T1
Started the car today and I think all the leaks are taken care of, however a new problem has come up. The engine would run for about a minute and then it died. Theres was some white/grey smoke coming out the tailpipe. Tried it again and it lasted a little longer but died again. It also had some smoke with it. Both times i started it the rpm were about 1200 for a few seconds and then dropped to about 800. I also checked the fault codes and got 12, 13, and 37. 12 was about the battery disconnected, 37 was something about the torque converter but 13 said the MAP sensor was not getting a proper reading. So could a problem with the MAP sensor be causing these problems or should I be looking elsewhere?
