Wallace:
https://www.fwdperformance.com/Store...xtCatalog=1985
This is where I got the ECU from, it is the stage 3 (last one). What is next to it for info is all I know about it. So it says it should work with stock injectors. I have a full set of +40's that I did not install because I was told I may not get a good mixture.
.....ok, so I just went and did some research on the
MAP sensor and
AIS. The ECU has the
map sensor built into it as seen it the pic on the website (its the black part). I remember when I received it the
MAP sensor was not on it and there was a plug on the inside with I think 3 wires, I dont have the time now to go take it apart and look but I am now thinking that that is what needs to be plugged in to fix the idle problem. A new problem though is that I am not sure what wires to plug into that. Any suggestions on that?
Tryingbe:
Not sure on codes, but as stated above I think I may not have it hooked up right yet.
Cawcislo:
I have no dummy lights in the care anymore. As you can see in the pic, I reconfigured my dash and bought all new gauges (went a little overboard on the tach but oh well :P). So looking at everything you are telling me it was probably a bad idea to take all that out :/ Looking into the
AIS (
Turbo I to Turbo II) I dont really understand what it means by 4 wire connector, none of the ECU's I have looked at have 4 connectors?? I also dont know how I would add 2 wires and am not sure what that is for.
[IMG]/Users/Steven/Pictures/iPhoto Library/Masters/2012/09/05/20120905-102430/IMG_3984.JPG[IMG]
(Not sure if this image will work or not)
