oil pressure guage is wrong - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 6 Old 11-20-2012, 07:31 PM Thread Starter
My Ride: 88 shelby Daytona
Engine: 2.5 turbo II
ok the oil pressure guage on my 91 daytona 2.5 turbo is wrong it says verl low but i have replaced the oil punp and sending unit and have put an after market guage on it and it says it has good press. so is there a way to repair the gauge? .....oh the temp gauge is doing the same thing. Any help would be great THANKS
adamj99 is offline
post #2 of 6 Old 11-20-2012, 09:09 PM
Re: oil pressure guage is wrong
Yeah ignore them, and buy good quality aftermarket ones. The stock ones are only a generalization of what your motor is doing.
Or go find another cluster out of a donor car.
I had a 91, but a V6 same cluster though, same prob, went to full auto meter ones, and had to train myself to ignore the stock ones, most stock gauges on most cars are not that accurate anyway.
Just my two cents.
Good luck
Last edited by GhostDaytona; 11-20-2012 at 09:11 PM. Reason: iPhone, no buttons, aaarrrggggg.
GhostDaytona is offline
post #3 of 6 Old 11-20-2012, 09:12 PM
My Ride: GLH Omni
If you want the dash gauge to read higher, I would try another cluster OR remove the cluster tear the clear plastic widow off, and pull the needle very carefully and rotate the needle and stick it back on.
You may want to have the engine at idle while reinstalling the needle so its in the correct spot.
speedfreek500 is offline
post #4 of 6 Old 11-21-2012, 07:41 AM
Just A Guy
NAJ's Avatar
If the gauge moves full sweep the problem is not in the gauge, the problem would be with the sender or excessive resistance in the wiring.
post #5 of 6 Old 11-21-2012, 08:32 AM
Garrett Booster
My Ride: 89 Shelby Lemon
Engine: An odd mix of 2.2 and 2.5 engines.
this is more than likely the problem. Between my 3 engines i have 2 with dead water temp sensors and 2 with flaky oil pressure senders. I would check those and the wiring before you go blaming the gauges.
Or just throw on some aftermarket gauges, which will have brand new sensors and wiring.
cegan09 is offline
post #6 of 6 Old 11-22-2012, 11:31 PM Thread Starter
its not the sender i have chandes it out with one that i know works(its on my other car)
adamj99 is offline
Human Verification
