Well almost there i thing just slowly working bugs out - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 11-26-2012, 11:57 PM   #1
Lightbulb Well almost there i thing just slowly working bugs out
My Ride: plymouth horizon
unclerico is keeping the peace
Ok so i had fault codes 13 and 14 recently. So i checked connections and also cleaned the solenoids started the car idles great one problem no throttle responce... Untill i let off then it revs. Got fault code 24 tps sensor which makes perfect sense so should i just replace the sensor and that should fix it or does it sound like something else is wrong.
unclerico is offline
Old 11-27-2012, 08:28 AM   #2
Re: Well almost there i thing just slowly working bugs out
NAJ's Avatar
Feedback: (21)
Diagnose the problem then replace the parts needed.
You always start with the lowest Code # and work your way up but in this case with a Code 13 and 24 sets with throttle movement I would start with the Code 24.
Sure sounds like the TPS is the issue but be sure voltages are correct, takes all of 15 minutes.
1)Disconnect TPS connector
2)With the key on/engine off with a digital voltmeter probe(backprobe the connector) the Reference and Signal Return Line.
Voltage should read 4.90-5.00 volts.
3)If correct reconnect the TPS connector.
4)With the key on/engine off backprobe the Signal and Signal Return Line.
a)Voltage at closed throttle should be below 1.00 volts but not below .10 volts.
b)Slowing sweep the throttle open while watching your voltmeter, voltage should increase consistently as the throttle is opened.
If voltage spikes or drops while sweeping replace the TPS.
c)At WOT the voltage needs to be above 3.50 volts but not higher than 4.90 volts.
Tell me what year car we are working on and I can give you the wire colors for your TPS.
Jan
1990 Daytona Shelby VNT
34 Years ASE Certified
Old 11-27-2012, 10:03 AM   #3
89 ecu thanx for your help
Old 11-27-2012, 10:11 AM   #4
NAJ's Avatar
Feedback: (21)
5 Volt Reference...VT/WT
Signal...OR/DB
Signal Return...BK/LB
