1.. oil smokes out the back, cause?
bad turbo seals.... almost 190000 on it. Tired turbo?
2..oil drain back return line clogged? car sat for
4-1/2 yrs till I bought it back.
3.. oil feed line to turbo, clogged and or ruptured
or possibly small hole?? turbo hasn't burnt up, still pulls.
4..oil in my vac lines, cause?
PCV not checking properly?
Wrong
PCV? Maybe clogged oil/drain back line causing
over pressure, reason for oil problem?? But, would that
also be a cause of oil coming out of the top of the dipstick
handle? NOT the tube, the handle itself, where it curls
back over into a question mark, right at the tip, oil blows
out???
Any suggestions, comm. an leak down ill do in the morning
before I crawl under the car.
