01-07-2013, 08:32 PM
#16
Re: Stalling... Help!!
Level 2 Supporter
My Ride: CSX/Omni/Shel-Dak
Engine: 5.2 & 2.2 turbo
Originally Posted by Rustic4x4
same kinda problem. every time i come up to a light and put the cluch in it dies.most times. just put in brand new k&n air filter , new plugs , wires , PCV valve and new belts..i was told it could be the alternator.? everything else on the car works great! minus the tach.but thats another story..please help! new alternator is 200 bucks so id like to get some ideas before i buy one....thanks!
I would definitely say it's not your alternator. You need to check for codes. Your problem could be a speed sensor issue, since you have a cable speedo, you wouldn't see a problem there. As for the tach, most likely need to take the cluster out and re-flow the solder on the tach circuit board.
