01-07-2013, 02:00 PM
Re: Boost pulls back to 5psi under full throttle HELP
Originally Posted by GLHNSLHT2
ECU pulling back the boost because of detonation? Need a scanner on it to see. One thing to check out would be the SoCal SDAC meet at applebee's in LaHabra the 1st thursday of every month.
Thanks for the tip in the SDAC meet, I'll probably try to go next month. I live less than 15 minutes from there.
As far as detonation, I don't think that's it. Seems directly related to throttle position and I definitely don't hear even a little ping.
FWIW, the car recently had the cyl head rebuilt and all the hoses were replaced as well as the TPS at that time, this issue stared afterwards. I'm leaning towards the suggestion that ChargedDust made regarding the orifice fitting. I haven't looked for it yet, but if that could cause such a problem then that's likely the culprit.
I will be back here if the problem persists after checking for the orifice fitting.
