Tranny/Clutch problem? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 01-07-2013, 07:50 PM   #1
Unhappy Tranny/Clutch problem?
My Ride: 90 Daytona VNT
Clugmuffer is keeping the peace
When I put the car in 1st gear and try to drive off, it feels like I'm in 3rd. Very bogged down, almost stalls, doesn't feel right. I tried 2nd gear just in case, feels even boggier. Drove back home (less than 1 block), smells like something was burning. But shift into reverse, it works totally normal. Car was working fine the night before and for the 2 months before that. The clutch was replaced and the tranny was rebuilt in the last ~3 years, without alot of miles put on since.
The only thing I checked was to see if a brake was stuck on, put they seemed ok....
1990 Daytona (formerly) VNT
Clugmuffer is offline
Old 01-07-2013, 08:23 PM   #2
Re: Tranny/Clutch problem?
Level 2 Supporter
dragbaron's Avatar
My Ride: CSX/Omni/Shel-Dak
Engine: 5.2 & 2.2 turbo
Feedback: (36)
dragbaron is keeping the peace
I'd say check your shifter bushings that are on the ends of you shift cables first.
dragbaron is offline
Old 01-07-2013, 09:05 PM   #3
You mean the ones under the stick shift? I replaced those with poly bushings a few years ago, but it's not hard to check....
Or are there bushings on the transmission itself?
Old 01-07-2013, 09:33 PM   #4
Level 2 Supporter
dragbaron's Avatar
Feedback: (36)
There are ones on each end of the cables, under the shifter, and at the trans levers. May also want to check that both of the adjustments on the shifter end of the cable haven't come loose. I've had a car that wouldn't go into 5th, and found out the cable bracket at the trans had come loose. Last thing I can think of is the lever that's on top of the trans controls the side to side movement, and the lever will come loose. It's held on by a roll pin, and when it gets too loose, you drill the lever and the shaft out to the next size roll pin.
'91 Spirit R/T=red(The "REL PUBLICAS" car?)http://www.turbododge.com/forums/f11...tions-r-t.html
'91 Spirit R/T=white(It came back to me!)
'90 Lebaron Cpe GTC/VNT(Was)=2.5/5spd(Building motor)
'88 Lebaron Cpe-2.2 turbo 5/spd
'85 Omni GLHT-2.2/5spd(The "Project GLH.com" car)http://www.turbododge.com/forums/f1/...ctglh-com.html
'89 Shelby CSX #365
'88 Shelby CSX-T #249(It was free!)
'89 Shelby Dakota #673(5spd swap done!)
'87 Shelby GLHS #254
Old 01-08-2013, 07:49 AM   #5
NAJ's Avatar
Feedback: (21)
Have someone move the shifter thru the gears and watch the cables at the trans end.
