01-29-2013, 01:34 AM
#25
Re: GM 3100 V.S. retainers Why? what an I missing
TD Extreme User!
Engine: 2.5L TIII DOHC
Originally Posted by The Pope
when people read posts from Turbovanman on the conicals keep in mind that other than my self he was the third to try them. But unlike me and Detobias who has been running them for years now. Turbovanman didn't follow directions and put in the 3.3 springs without shims, which makes for way too little seat pressure.
The bad thing about running the Beehives, a Com Cams brand name for conical springs BTW, is that the Beehives have the S60 springs seat and open pressures for a big cam. A lot of pressure for a stock cam, more than you need. So I mention the 3.3 springs or the MP 813 springs which are a cheap MP spring with dampener at near stock turbo spring rates.
Lastly 92TurboTona is not going to be running 5,000 RPM with the plenum and the cam, it is going to fly to 7,000 RPM. So in your case the Beehives are a good idea. Yeah $100 in springs vs $60, wah.
You seem to forget that there was no mention of shims back then and why would you want to shim a spring a ton, seat pressure closed is 60 psi? If you want to shim a ton, knock your socks off. $100 in springs? Where, unless you get someone to split a set, your spending alot more than that.
Its called advice, deal with it. Everyone has different goals, the OP mentioned not revving it out incase your reading comprehension sucks. Some people don't want to spend $200+ on springs, retainers etc when HD replacement springs work fine for the mass's. Better go tell Shadow his regular springs don't work on his almost 9 sec Shadow.
1989 Turbo Caravan-2.5 TIII auto, 12.57@104
