01-20-2013, 10:37 AM
#13
Re: need help overboosting problem
My Ride: 86 ghlt
Engine: 2.5 Intercooled Turbo
I bought one of these (high performance boost controller)on ebay a while ago. bottom line....junk. it will absolutely not work the way they show it hooked up in the instructions. my advice throw it away. use the stock boost controoler till u can get a better one. if you want to try to make it work you have to hook it up like this:
Simple bleed system
Doesn't get much simpler then this- The restrictor keeps you from having to have a MASSIVE bleed to open the wastegate enough and the check valve keeps you from having a vacuum leak when not under boost.
Problem- Boost goal may or may not creep past set point and spiking maybe and issue. Very sensitive to restrictor size, playing around with different ones came minimize problems and achieve desired results. Also boost pressure can prematurely start to open wastegate with this setup slowing spool time, not really an issue with most wastegate cans that have the heavy spring, could be an issue with some cars though.
Note- The bleed valve in this system can be mounted inside the car which is handy for fine tuning desired boost level. (from thedodgegarage.com)
