01-24-2013, 11:13 AM
Re: Wipers barely work
Level 1 Supporter
My Ride: SC/GLHS(2)/CSX
Like I suggested in the earlier post, the ground strap can LOOK clean and shine like a super nova and still be crap as a ground. The design is such that no matter how tight you make the bolt the connection wont get any better. The center bushing referenced above is a dealer or site sponsor vendor item as indicated. To replace that one, you mark the position of the arm that is pressed on the assembly, its a press fit and if you reassemble with the marks in a different position, the wipers will be out of time, hit the windshield trim or even worse gouge the paint on the cowl. I've rebuilt several of these and I've made the mistakes I've mentioned...including looking for hours at a problem that was the ground strap all along.
