HELP! Engine cuts out after fillup - NAJ!!! - Page 4 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 02-04-2013, 06:07 AM   #46
Re: HELP! Engine cuts out after fillup - NAJ!!!
NAJ's Avatar
Feedback: (21)
I can get you diagnostics for the body and communication code but not until Wednesday, working open to close Monday and Tuesday.
NAJ is online now
Old 02-04-2013, 07:04 AM   #47
[X]treme Aggression
[X]treme R/T's Avatar
My Ride: Spirit R/T
Engine: T3, Alky+Holset he351cw
Images: 4
[X]treme R/T is keeping the peace
so yeah, when i change the plugs and take the throttle body off and give it a complete cleaning, ill reply back with the results because i read in multiple forums that bad plugs cause feedback to the pcm causing this issue.
in one of them a dodge specific mechanic spent 30 hours of diagnostic testing on a clients car that was having the same exact issue i was, and he changed everything the from steering sensor, tps, coils, injectors, cam position, crank position, pcm, canbus 1 and 2, pcm and the accelerator pedal sensor and it stil had the issue.
he said all it ended up being was the spark plugs. i read the thread at work and cant remember it 100% but he said something about when the factory copper plugs start to die out / before they actually missfire, that they cause a high resistance in the coil and it feedsback to the pcm causing the problem.
in my hemi / all the hemi's, one big coil controls both of the plugs per cylinder, so it kinda makes sense..
any thoughts on this / ever come across something like that?
[X]treme R/T is offline
Old 02-04-2013, 08:38 AM   #48
[X]treme Aggression
My Ride: Spirit R/T
Images: 4
found this also
*Symptom/Vehicle Issue: Intermittent Engine Die Out*
Customer may experience a die out, stall condition at any speed while driving or while at a stop. The engine usually restarts right away on a crank attempt. The symptoms may also be described as the engine appearing to lose power with a report that it restarts by itself. They may also be described as a missing, bucking or hesitation. Symptoms may also be accompanied by a MIL on with DTCs set. The actual DTCs may vary, however P0688 - ASD Relay Sense Circuit Low is usually set in PCM with possible power-up-at-speed or loss of communication DTCs set in various modules.
*Diagnosis:*
The only sure way to diagnose this condition is to capture the event with the data recorder. Graphs of some or all PCM data items during the event will usually indicate a loss of PCM "consciousness" or
communication represented in blank data for a given time on the graph.
Repair Procedure:
If the above conditions are present, inspect all spark plugs and coils for damage, signs of arcing or other abnormalities. If nothing is noticeable, replace all spark plugs and retest for the condition. If the condition is still present, start by replacing one coil. If the condition is still present, continue moving that new coil around to the other cylinders to substitute for the other coils in a process of elimination until the condition is no longer present. Replace the last coil that was substituted for just prior to the elimination of the condition.
NOTE: BE SURE REPLACEMENT SPARK PLUGS ARE O.E.M. THERE HAVE BEEN INSTANCES WHERE AFTERMARKET PLUGS ARE MARKEDLY DIFFERENT THAN OEM SPARK PLUGS. (FIG 1.) PARTS AND ARE PROPER FOR YOUR APLICATION. CARE SHOULD BE TAKEN DURING SPARK PLUG INSTALLATION TO REDUCE THE CHANCE OF DAMAGE TO ANY PLUG INSTALLED AND TO KEEP NEW PLUG INSULATORS CLEAN.
Old 02-04-2013, 05:59 PM   #49
NAJ's Avatar
Feedback: (21)
The only thing I ever came across that was similar was GM cars with distributorless ignition/waste spark ignition.
Since 2 plugs were fired simulaneously (one - and one +)if an ignition wire had excessive resistance or went open it was easier for the current to flow back to the coil pack and ground thru the - side ground.
This would cause the coil pack to fail and it would damage the ignition module that the coil pack was bolted to resulting in a no start condition.
Replacing your plugs is a cheap repair try to see if it corrects your issue.
From working on Jeeps for 15 years i can tell you the average life of a Champion Copper plug is about 25,000 miles.
Jan
1990 Daytona Shelby VNT
34 Years ASE Certified
NAJ is online now
Old 02-04-2013, 08:37 PM   #50
[X]treme Aggression
My Ride: Spirit R/T
Images: 4
yeah and the recomended replacement is 30k miles.. lol
yeah i get the plugs in tomorrow or the following day, ill update on the results.
Old 02-05-2013, 05:12 PM   #51
[X]treme Aggression
My Ride: Spirit R/T
Images: 4
put new plugs in, and cleaned the throttle body.. TB was caked in a thick layer of carbon /sludge
took it for a spin, runs better, sounds better, more power, and no more cut out issue!!!!
its gone completely and runs like a champ
pic of my throttle body before i cleaned it
wrong plugs were in / pulled out e3's / put in new factory oem champion copper plus's
Old 02-06-2013, 06:51 AM   #52
NAJ's Avatar
Feedback: (21)
NAJ is online now
