how to replace alt. belt 89 lebaron - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 02-16-2013, 01:10 PM   #1
chryslerfan is keeping the peace
I need to replace the alt. belt. It looks like the only way to do this is to remove the a/c belt and it looks like you can't get to the crankshaft wheel without taking off the a/c belt. Is this right? I would like to replace the alt. belt without taking off the a/c belt if possible. I would really appreciate it someone could tell me how to replace the alt. belt and if the a/c belt has to be off first how to do that. I don't see a belt tensioner.
Thanks
chryslerfan is offline
Old 02-16-2013, 03:28 PM   #2
Re: how to replace alt. belt 89 lebaron
Moderator
Jakecs's Avatar
My Ride: 1988 Daytona CS
Engine: 2.2L Turbo I
Jakecs is keeping the peace
Yes the A/C belt will have to come off. That's easy though, it takes like 2 minutes.
The whole job shouldn't take more than 10-15 min.
Loosen the A/C tensioner pulley, between the compressor and the crank pulleys. The belt should come off pretty easily.
Next, there should be a bolt on the alternator belt tensioner. You can find this bolt on the right side of the alternator(your left). Loosen this bolt, do not take it out.
Next, facing the front of the alternator there is the adjust bolt, which you'll notice is very long. Loosen up the belt with this. Just take it as loose as you need it to slip the belt off. Reverse process once you get the new belt on.
Pretty simple.
Jakecs is offline
Old 02-17-2013, 06:10 AM   #3
NAJ's Avatar
Feedback: (21)
Old 02-17-2013, 08:15 AM   #4
thank you i appreciate it. what website are these schematics from?
Old 02-17-2013, 08:55 AM   #5
TD Extreme User!
Feedback: (47)
tryingbe is keeping the peace
No website.
It's from factory dodge repair manual.
tryingbe is offline
