02-25-2013, 08:45 AM
Re: More oil leaks
ENTER 4 MAY COTM!
My Ride: 89 Daytona Shelby TT
Engine: 2.5 TII
Assuming this is a 2.5 T1, have you tried driving it without seeing any boost (disconnect wastegate vacuum) to see if it leaks? Mechanic probably checked but under alittle boost and a dirty PVC you can get oil squirting out of the cam seal or anywhere along the valve cover gasket on that side.
I actually replaced the crank seal on the passenger side and it was really the cam seal passing oil under boost. I thought it was the crank because most of the mess was down there
