Starting system problems - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 03-07-2013, 06:17 PM   #1
Garrett Booster
My Ride: shelby daytona's
Engine: 2.2 turbo
zuke is keeping the peace
My Bosch starter would always go clickity click click when it would rain, or if there would be moisture in the air. Other than bad weather it would always work fine. I decided to replace it with the more reccomended nippondenso (according to what I was told on this site) And now after it was installed the starter will not turn the engine over. there is no noise, not even the relay clicking or engaging, I used to hear before I switched starters.
I took apart the relay and turned the key on amd pushed the contacts of the relay together and the starter started the engine.
I since replaced the relay but still nothing, no relay contact click noise, no starter engagement-nothing. Do you really think It could be another bad relay.
zuke is offline
Old 03-07-2013, 07:35 PM   #2
Re: Starting system problems
Una
Wise [arse] old TDer
Una's Avatar
My Ride: '84 Dodge Rampage
Engine: 2.5L
Feedback: (9)
Una has Reached TI StatusUna has Reached TI StatusUna has Reached TI StatusUna has Reached TI Status
Light brown with a yellow stripe wire going to that relay, ground it and the ignition switch will work. That's the neuteral safety wire on an automatic (if you have an auto, you need to fix the reverse/neuteral switch on it).
Una is offline
Old 03-08-2013, 05:29 AM   #3
My Ride: 85 dodge glh turbo
jordensk is keeping the peace
Sounds kinda obvious but ill state it neway. Make sure battery is fully charged, I had similar probs on my glh. If the batt is low enuff the relays wont wrk, but u can still have enuff volts to start if u jump the relay. Will it start correctly on jumpers or batt charger?
jordensk is offline
Old 03-08-2013, 10:08 PM   #4
Garrett Booster
Engine: 2.2 turbo
Battery is brand new just bought it at the dodge dealership-$137.00, it is fully charged.
zuke is offline
Old 03-08-2013, 10:38 PM   #5
Level 2 Supporter
My Ride: STI
going4speed is keeping the peace
The connection from the starter solenoid is a single wire that terminates at a plug near the battery. I would check the plug for good continuity. Unplug, clean, dielectric grease and try again.
going4speed is offline
Old 03-08-2013, 10:42 PM   #6
Una
Una's Avatar
Engine: 2.5L
Feedback: (9)
It's the freakin neuteral safety wire that needs to be grounded. This problem is as old as TD's. Happens on a weekly basis. Ground that brown-yellow wire, it'll work.
Una is offline
Old 03-19-2013, 07:20 PM   #7
Garrett Booster
Engine: 2.2 turbo
Thank you for your help UNA, it was exactly that. The ground wire broke off the eyehole connector on the bolt to the tranny.
zuke is offline
Old 03-20-2013, 09:30 AM   #8
Level 1 Supporter
ILIKESHELBYS's Avatar
My Ride: SC/GLHS(2)/CSX
Feedback: (13)
ILIKESHELBYS is keeping our cars running
Yup..... Been there, did that. Brown and yellow wire that grounds to the tranny case was my problem also. I even bought a 2nd starter and installed it and still no joy...well till I was told here to check that wire!
ILIKESHELBYS is offline
