Crank Intermittent no start/Strt Stall - Page 4 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #46 of 108 Old 04-09-2013, 08:47 PM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
Re: Crank Intermittent no start/Strt Stall
Thank you for the suggestion Steve. Unfortunately, it doesn't have a factory alarm.. or I would be running out there and scavenging the battery from my wife's caravan to try it...lol
MikeSquared is offline
post #47 of 108 Old 04-09-2013, 08:55 PM
Boost is a good thing!!
Steve in Va's Avatar
My Ride: 86 GLHS #295
I had no idea mine had one either. Hell, I never did find it or even look for it, but I remember the hood pin sensor. Does your have the hood pin sensor on the drivers fender in between the battery and shock tower (blue arrow)
Steve in Va is offline
post #48 of 108 Old 04-09-2013, 09:11 PM
Una
Una's Avatar
My Ride: '84 Dodge Rampage
Engine: 2.5L
If it's the factory alarm, unlocking the driver's door with the key will disarm it. If it has one.
Una is offline
post #49 of 108 Old 04-09-2013, 09:22 PM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
Crank Intermittent no start/Strt Stall-20130409_211138.jpg
I have no clue what the black plug on the fender well was for. Never noticed it before...
Interesting....
post #50 of 108 Old 04-09-2013, 09:23 PM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
That is the next step one the battery charges tomorrow..lol
post #51 of 108 Old 04-09-2013, 09:52 PM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
heck with it... I took the battery from my wife's GC. I tried what you said... and nothing. I dont think there is a factory alarm...
Oh well.. worth a shot
post #52 of 108 Old 04-10-2013, 01:24 PM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
Could cranking the engine with the asd grounded damage the sbec?
every test I have done, according to the flow charts, says replace the controller...
post #53 of 108 Old 04-10-2013, 03:08 PM
Una
Una's Avatar
Engine: 2.5L
Nope, I've driven around in a van that had a bad ASD driver transistor, the ASD was jumpered, and it ran fine. This is much like the toggle switch to the fan relay that a lot of people do to get manual control over their radiator fan.
Una is offline
post #54 of 108 Old 04-10-2013, 07:42 PM
Just A Guy
NAJ's Avatar
Just to recap and verify...
While cranking the engine there is no power to the + coil, DG/BK wire at the injector harness and fuel pump...
Is this correct?
post #55 of 108 Old 04-11-2013, 10:17 AM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
Incorrect. I have power to coil +, and coil - will flash the test light for 3 to 4 sparks then it shuts off.
Power to the pump.. same issue.
hall sensor getting a reading (5.1v when the pickup lines up, 0v when it isnt).
ASD can be felt clicking on and staying on until the key shuts off.
I printed out ran the NS tests, and every one (except for checking the fuel injector harness) pointed to changing the SBEC.
post #56 of 108 Old 04-12-2013, 06:40 AM
Just A Guy
NAJ's Avatar
Verify....
1)You are not losing any power feeds at the ASD relay.
2)The power output at the ASD is shutting down during cranking.
post #57 of 108 Old 04-12-2013, 08:43 AM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
At ASD...
RD/WT 12.6v
DG/BK no power key on. Initial cranking 12.6v then drop to 0 (decline over 1/2 second, not sudden 0).
DB Constant 12.3v
DB/YL 12.3v then to 0v -.1v (fluctuating) while cranking. When cranking stops and key returns to run, goes back to 12.3v.
Can you please post NS7? I went over my notes and saw I have not run that one yet.
All the rest (except fuel injector harness which I have not run) show to change the SBEC. Just wanted to clarify since the prior post read as if that test showed something besides changing the SBEC, but I had not been able to run it.
post #58 of 108 Old 04-12-2013, 11:42 AM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
Just went and ordered a stage 2 from Cindy. So the car is down another week and or so.... at least it will be up and running happy.
I figured... if every test I have done says change SBEC, it has to be that.
Just wondering how it died...
This went from a clogged fuel filter to this mess. I wonder if I popped the computer when I was testing stuff...
post #59 of 108 Old 04-12-2013, 08:03 PM
Just A Guy
NAJ's Avatar
I hope that the controller is your issue since you bought one but...
At this point you verified that both power feeds(RD/WT and DB) are still present at the ASD Relay when power output stops which leads to one of 2 problems...
1)You are losing the ASD Relay ground control which is the DB/YL wire and computer controlled.
2)You are losing the crank signal to the controller.
If you had a scanner you could easily tell(less than 1 minute) if the crank signal is the issue.
Go to Data Stream, look at RPM and crank the engine, if the RPM reading drops to 0 the controller is not seeing a crank signal.
Before condemning a controller you need to check 2 things.
1)All controller power feeds and grounds are present.
2)There are no "pushed out/spread/broken internally/corroded" terminals in the controller connector related to the affected circuits.
Jan
1990 Daytona Shelby VNT
37 Years ASE Certified
post #60 of 108 Old 04-13-2013, 12:33 AM Thread Starter
Garrett Booster
My Ride: 90 Shelby
Engine: 2.5 T1
By crank signal, do you mean the HAL sensor? If so, the signal is present at the connector and the wire shows omhs within range ( can't remember now but it was within test range when I did it).
If the asd is grounded and the car still doesn't start, can that eliminate the asd ground control as a culprit?
I will be doing the tests in the morning. But as for ordering the controller, I had planned on doing it anyway by the summer so it's fine.
Human Verification
