No start problem - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 8 Old 04-06-2013, 10:23 PM Thread Starter
My Ride: 87 daytona shelbyz
No start problem
I have an 87 daytona shelby z that I recently aquired which supposedly ran before it had sat for a couple of years. I replaced the HEP and the Coil and the power control module. One of the plugs in the harness for the dist. was missing?? chewed off by rodents, I was able to get it connected to the plug from a wiring diagram and I have spark. I have a code 12 and 26 with 1-2. I replaced the fuel rail with a spare I have and get the same codes. I did the turn the key of and on 5 times and get the power loss light blinks twice. The engine will fire and run for about 5 to 10 second and shut off. if you turn the key off and start it again it will do the same thing. If you try and start it with out turning the key back it just cranks and doesn't start. I also checked the fuel pressure and it is good even after it dies. If anyone can direct me in a direction to go I would appreciate the help.
jonb is offline
post #2 of 8 Old 04-07-2013, 05:53 AM
Just A Guy
NAJ's Avatar
Re: No start problem
Welcome To TD!!!
After clearing the codes and cranking/starting the engine does Code 26 come back?
If so you need to use a noid light, logic probe or DRB2 and voltmeter to check for injector power/pulse.
Connecting a noid light and cranking engine does light...
1)Iluuminate but not flash
2)Not illuminate at all
3)Pulse on/off
NAJ is online now
post #3 of 8 Old 04-07-2013, 09:35 AM Thread Starter
Yes the code comes back if you reset codes. I thought it might have been a bad injector that is why I changed the fuel rail and injectors. I will get a noid light and put on it and check it. thanks
jonb is offline
post #4 of 8 Old 04-07-2013, 02:33 PM Thread Starter
I put the noid light on the fuel injectors one at a time. 1 and 2 do not light at all and 3 and 4 blink but are not overly bright. the white wire from the power module checks good and I checked power at the plug and do not have it. Is the power module bad or does the logic module have separate control wire for each side. I have the wiring diagram but it just tells the color code on the wire and is not specific for what it controls. The power module is new not saying it couldnt be bad. Any Idea on which direction to go?
jonb is offline
post #5 of 8 Old 04-08-2013, 05:27 AM
Just A Guy
NAJ's Avatar
The DG/BK wire is the power feed for the injectors from the PM 10 pin connector cavity #6.
This is the ASD relay output which also powers the fuel pump and + coil.
If the PM is the issue you will not have any power at cavity #6.
Be sure the terminal is not broken/pushed out in the connector if no power is present.
Manually actuate the ASD and see if power is present at the fuel pump,+ coil and injector connector DG/BK wire.
To manually actuate the ASD....
1)Locate the diagnostic connector
2)With the key on/engine off ground the DB/YL wire in the diag connector.
(A code 42 will be set in memory, not a problem)
Post Back with your results.
Jan
1990 Daytona Shelby VNT
38 Years ASE Certified
NAJ is online now
post #6 of 8 Old 04-08-2013, 02:42 PM Thread Starter
I do have power at the #6 socket. I have also found a wiring diagram showing what the pin out is for the logic module and power module, and found there is separate wires for each side of the fuel injection system. I tested continuity in the wires from the logic module to the power module (tested good). I tried to test the wires for power or ground connection and have had no luck in checking the signal from the logic module to the power control module on either wire. My test light may now work correctly with low volts. I will assume the logic module is bad. Let me know what you think. I appreciate the help.
jonb is offline
post #7 of 8 Old 04-09-2013, 11:10 AM
Just A Guy
NAJ's Avatar
PM sent with Code 26/27 No Start Diagnostics
NAJ is online now
post #8 of 8 Old 04-10-2013, 06:16 PM Thread Starter
Replaced the Power module (was a reman from loacal auto parts store) and it fired right up. Thanks for all the help NAJ
jonb is offline
Human Verification
