Heat shield - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 12 Old 10-09-2013, 02:57 AM Thread Starter
Moderator
nvysion's Avatar
My Ride: Chrysler ES
Engine: 2.5L intercooled
Heat shield
I must changer the starter on my shadow, there is no heat shield and I would like to add one.
Does someone can post pics showing how it look like ?
Thanks
Louis
nvysion is offline
post #2 of 12 Old 10-09-2013, 08:56 AM
- OFFICIAL GEARHEAD -
ILIKESHELBYS's Avatar
My Ride: SC/GLHS(2)/CSX
Re: Heat shield
The OEM heat shield is no longer available. Sometimes you can find a useable one in the salvage yard on a cream puff. Else, you have to buy a starter heat shield/wrap at your choice of auto parts speed retailer such as summit racing.
Try this link for a list of available selections:
http://www.summitracing.com/search?S...0shield&page=2
ILIKESHELBYS is offline
post #3 of 12 Old 10-09-2013, 09:06 AM
Let there be Boooost
yellonoma's Avatar
My Ride: 89 Daytona Shelby TT
Engine: 2.5 TII
Re: Heat shield
I find the stock heat sheild causes more problem than good and would recommend a heat wrap. Often for local in my area, the new starter comes with the heat shield.
If you haven't purchased yet, see if you can find one that does, but not sure on your situation on parts in France Louis
I don't have a picture but it has a single screw hole that bolts to one of the solinoid screws, and formed to cover the entire top of the solinoid and starter motor, as well as two rubber bumpers that rest against the starter motor.
89 Daytona Shelby T-top - Project / 88 Dodge Aries-K... "K-Machine Project" / 90 Daytona ES Turbo / 89 Aries-K
- COTM AUGUST '11 / COTM MARCH '12 -
Production Figure Database
New to the forum? Say Hi and Introduce yourself to the community!
yellonoma is offline
post #4 of 12 Old 10-09-2013, 11:56 AM
TD Hardcore User!
My Ride: Daytonas
Re: Heat shield
I put one on my '89 like this...
Started having issues so I got a new one, when we went to do the swap we found that the foil had flaked off and crumbled away basically just leaving the blanket. Also found the starter solenoid had been burned on one side.
I looked up a new OEM heat shield and ordered it from Chrysler, the new one seems to be different than the way I remember the original (what was left of it). Haven't installed the new one yet but plan to soon. And it was still available, and wasn't expensive at all.
There is the possibility that wrapping the starter actually keeps the heat in, when in fact what you want is a shield that just fits between the what source and the starter and leaves the rest exposed to open air for cooling - remember that the starter is going to soak up heat just from being in contact with the engine.
If you don't like the Chrysler one, admittedly it looks pretty flimsy, I'd recommend a shield like this as opposed to a wrap. Just sort of bend this one in place and secure it with some metal zip ties. On the positive side these should be available to you locally in Europe.
ChargedDust is offline
post #5 of 12 Old 10-09-2013, 12:37 PM
Re: Heat shield
The OEM factory heat shield is the way to go. I didn't think they were available any longer. Last time I checked they were NS1 but obviously they made another run. Get them while you can I guess!
Mopar #05234376
post #6 of 12 Old 10-10-2013, 02:39 AM Thread Starter
Moderator
nvysion's Avatar
Re: Heat shield
Thanks a lot for your help.
Louis
nvysion is offline
post #7 of 12 Old 10-13-2013, 10:38 AM
Re: Heat shield
These people actually have them in stock, I bought 2 at $15US each:
Chrysler Parts, Dodge Parts, Jeep Parts - Authentic OEM Car & Truck Parts Direct | FACTORY CHRYSLER PARTS
post #8 of 12 Old 10-13-2013, 12:14 PM
Super Moderator
Dr. Johny Dodge's Avatar
Re: Heat shield
hows about the clip ?
Dr. Johny Dodge is offline
post #9 of 12 Old 10-13-2013, 12:38 PM
TD Hardcore User!
My Ride: Daytonas
Re: Heat shield
Gives this as the part # for the clip, 5234377, but doesn't show as available.
post #10 of 12 Old 10-13-2013, 01:51 PM
Re: Heat shield
I was not able to find any sources online for the clip. Not hard to find in the salvage yard however if you find a car that has the (rotted)shield still in place. You might give "The Car Farm" a call first though. Johnny probably has them NOS or good used.
Mopar Used Parts - Chrysler Dodge Plymouth
post #11 of 12 Old 10-18-2013, 11:31 AM
Sid
Garrett Booster
My Ride: Dodge
Re: Heat shield
As of today, only 5 heat shields left in the entire country so if anyone needs any, I would get them ASAP.
Sid is offline
post #12 of 12 Old 10-18-2013, 05:23 PM
Re: Heat shield
Got mine today....they are puuurdy.
Human Verification
