Need help! Engine idles rough and cuts out under load. - Page 3 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #31 of 46 Old 02-09-2014, 10:14 PM Thread Starter
My Ride: 93 dodge stealth
Engine: 3.0l
Re: Need help! Engine idles rough and cuts out under load.
Fuel pressure under load I think is the next step. The fuel filter is new. I does feel like a fuel issue but that doesn't explain the popping and back firing.
ghetto Viper is offline
post #32 of 46 Old 02-09-2014, 10:27 PM
Level 4 Supporter
89TonaVa's Avatar
My Ride: 89 DaytonShelby TII
Engine: 2.2 Turbo FMIC
Did you pull plugs and check them since you replaced them? plug condition might clue you in on what to look at. it would seem to me ( some one will correct me if Im wrong) that if your backfiring it would mean raw fuel is making to exhaust and igniting. ans sputtering would be cylinder or cylinders missing due to flooded condition or lack of spark.
89TonaVa is offline
post #33 of 46 Old 02-09-2014, 10:34 PM
Level 4 Supporter
89TonaVa's Avatar
Ok just read this on back fire.What causes backfiring? - Yahoo Answers answer #4
89TonaVa is offline
post #34 of 46 Old 02-09-2014, 10:57 PM Thread Starter
Engine: 3.0l
The plugs and wires are new when I check the plugs they are black and covered in soot. When I pull a plug wire while its running the spark out off the boot seems strong.
post #35 of 46 Old 02-09-2014, 11:41 PM
Level 4 Supporter
89TonaVa's Avatar
Midnight Touge: Spark Plug Guide. Check this out.
Did it make a difference in idle when you pulled plug? and have to done that to each plug.
89TonaVa is offline
post #36 of 46 Old 02-10-2014, 07:48 AM
With the engine at operating temperature and while it is missing what is the vacuum gauge reading? Is it steady or is it moving around?
wallace is offline
post #37 of 46 Old 02-10-2014, 09:38 AM
Just A Guy
NAJ's Avatar
From everything I am seeing here Cam timing is correct.
Put the car back together, set ignition timing and move on to the next step of diagnostics.
If you are running "black" rich the issue is related to fuel pressure, low engine vacuum or map calibration/cts calibration.
See post #6 for the diagnostics you need to run that I posted earlier.
As you can see they are the same as Chryslers diagnostics for driveabilty issues with no fault codes or codes 51/52.
post #38 of 46 Old 02-17-2014, 04:15 PM Thread Starter
Engine: 3.0l
I found that the head was warped and fixed it put it back together and drove it still cut at 4000 so we pulled the plug wires and checked continuity when we put it the plug wires back on it wouldn't start I went to jump out the diagnostic plug and it started smoking and toasted at least one wire. I put a multimeter on it and had voltage on the diag plug? Now what I can't find a short.
post #39 of 46 Old 02-17-2014, 07:50 PM
Just A Guy
NAJ's Avatar
You went to jump the diag connector to actuate the ASD relay???
Did you ground the DB/YL wire??? or the wrong wire?
The DB/YL wire is the ground circuit for the ASD relay and you would only need to actuate the ASD if you have a no start or you are checking "static" fuel pressure.
post #40 of 46 Old 02-17-2014, 08:18 PM Thread Starter
Engine: 3.0l
I jumped it exactly like you have in the pic there and that spot was hot and I burned up a wire. I get 12 volts there when the key is on
post #41 of 46 Old 02-18-2014, 08:58 AM
Just A Guy
NAJ's Avatar
I once popped the cooling fan fuse manually actuating the ASD relay because of arcing during connection.
I will go out to my car later and tell you if and how much voltage is present on the DB/YL wire with the key on only.
Once you connect thy DB/YL wire to ground there will be voltage in that circuit because you are completing the relays control side.
The DB/YL wire runs to the controller cavity #58(ASD relay control)and to the ASD relay where it completes the control circuit for the DB wire.
The DB wire is powered from the ignition switch.
Which wire burned?
Jan
1990 Daytona Shelby VNT
38 Years ASE Certified
post #42 of 46 Old 02-18-2014, 10:23 AM
Just A Guy
NAJ's Avatar
Lets remember basic electricity...
Voltage is a pressure differential that causes electron flow.
Amperage is the actual flow of electrons.
Amperage blows fuses and melts wires, not voltage.
Key On/Engine OFF DB/YL Wire Voltage and Amperage
Voltage-Battery Voltage
Amperage-147 MA(.147 amps)
(When the + Ammeter probe was placed on the DB/YL wire the ASD relay was actuated(circuit to ground was completed)with absolutely no issues.)
If you melted a wire you had too much amperage flow which is caused either by a power wire shorted to ground, wire shorted to voltage or a shorted component.
(Short Circuit-Direct Path to Ground with No Circuit Resistance)
Jan
post #43 of 46 Old 02-18-2014, 01:37 PM Thread Starter
Engine: 3.0l
It was an orange wire and it went up fast like it went straight to ground. I have 12v at the DB/YL wire with the key on so of I ground it it will short out and burn more
post #44 of 46 Old 02-18-2014, 02:49 PM
Just A Guy
NAJ's Avatar
You obviously did not read my last post.
Also.where does the OR wire lead to?
post #45 of 46 Old 02-18-2014, 04:14 PM Thread Starter
Engine: 3.0l
Sorry I'm just frustrated. The orange wire goes into a rubber thing I'll get a pic. Then I loose it in the loom. Now the car is hit and miss for running. There appears to be no other damage. We tested the relays but they seem OK. Is there a wiring diagram somewhere I can get a copy of. Due to the speed which the wire went up I am afraid to ground the DB/YL wire until I can figure out what caused the short.
Human Verification
