Old 11-12-2004, 10:41 PM   #1
Timing belt noise
My Ride: 1987 Daytona Shelbyz
I installed a new camshaft, rocker arms, timing belt and tensioner in my 87 Daytona Shelbyz. I now have a whining noise that is coming from the inside of the timing cover. Twice, I used the timing belt adjustment tool to set the proper tension on the timing belt. The first time the belt was noisy at 1000rpm to 1200rpm. Now, after adjusting the belt the second time the belt is noisy only at idle when at operating temperature, and not noisy when cold. I can also can bend the timing belt with my fingers 90 degrees between the camshat sprocket and the intermediate shaft sprocket. I feel that the timing belt tension is correct. Could my cam, crank, intermediate sprockets be worn? Should I try to adjust the tension on the belt again?
Thank you
87blueshelbyz is offline
Old 11-12-2004, 11:18 PM   #2
I've never used the proper tensioning tool. I like to be able to twist the timing belt about 90* (maybe slightly more). You could try backing it off a touch... a timing belt too tight may tend to whine a bit. Other than that, hopefully someone else has some input!
Mike M is offline
Old 11-13-2004, 12:17 AM   #3
The whine is from the timing belt being to tight. It whines after getting warm/hot because the block and head expand and grow taller, causing the belt to get tighter.
Joe Dzwil
Matawan, NJ
JDIZZ is offline
Old 11-13-2004, 07:45 AM   #4
What "JDIZZ" say's makes sense. The belt must be just a little too tight. I don't know why I am adjusting the belt too tight with the proper adjustment tool? I won't have time to work on the car until Sunday afternoon. Thank you for your help.
Old 11-13-2004, 10:22 PM   #5
My Ride: 1987 shelby charger
Engine: 2.2 t1/t2 conversion
yupp i dont use tool......just try it at maybe 93 degrees
eef
eef mcglikn is offline
Old 07-28-2005, 05:51 PM   #6
Why do you mean by 90 and 93 degrees?
cj011 is offline
Old 07-28-2005, 06:50 PM   #7
ops meant 90 degree..........example . here is belt====> l
turn belt 90 degrees and it will look like this=========> []
or l0ok at this => l
l
l
twisted 90 deg.= > []
l
l
belt should twist to tight feel.
eef
Old 07-28-2005, 09:06 PM   #8
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Check the idler pulley bearings. Of course you are describing a noise by typing it to us. We don't even get the benefit of the "Meineke - 'It sounds like thbbbff pft pft wheezzzze'". Occasionally these go bad.
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
mpgmike is offline
Advertising | Online Advertising | Israel Hotels | Secured Loans | Remortgages
Page generated in 0.34946 seconds with 13 queries
