07-26-2005, 10:35 PM
My 2.2T 1985 Shelby
Ok, well, as you can see, I am new to this site writing all the way from Michigan(Three Rivers), but I do have an important question...
I have a 1985 Shelby Charger that I cannot get started for the life of me. I bought the car for 150.00, and it won't start up. It has spark, it has fuel, all the goodies, but won't start. I checked compression and it was fine, I checked fuel pressure, it was between 51-55psi(Stock specs...Right on)...I don't know what to do... Any help???Computer was checked, ASD relay, etc...Everything has been checked. New timing belt, was running fine aftewr it was changed...Possibly not tight enough??? Jumped time??? Here is the story...
The previous owner was drag racing some guy out at Martin, when he was going, the engine just totally shut down...Stopped running completely...It will crank all day, it will spark all day, fuel will smell if I crank it long enough, but won't start...Help me out!!!
Thanks!
Chris...
http://www.teamamf.com
p.s.- I cannot remember who I chatted with from on here at Martin, but thanks for the recommendations!
07-26-2005, 10:53 PM
It is the Turbo 2.2...I checked all the vacuum lines, but no leaks anywhere...Do you know where I can find a good cheat sheet w/timing markings online, firing order, etc??? Like a pdf file?
That would be awesome!
Chris...
07-26-2005, 10:59 PM
Originally Posted by bitsumitchi
btw, what is the timing order on the 2.2T?
On the blow through intakes it should be printed on the TB. I believe it is 1-3-4-2, but dont quote me on it.
About all you will need to know will be found at
http://www.thedodgegarage.com
and
http://minimopar.knizefamily.net/index.html
Hope this helps.
07-27-2005, 03:16 PM
My Ride: 85 GLHT
Yeah I think it will help out a lot. I am going to get started on it tonight...Either that, if I cannot get it running, just going to sell the damn thing..lol
I'll be on my way up 131 end of August. Just let me know....
Craig
07-27-2005, 03:23 PM
#12
My Ride: 87 Shelby Charger
I had this problem, try swapping out the power module.....if not it could be a fusible link.
